Wiring an AMP Meter!
Posted 19 September 2006 - 06:01 PM
Posted 19 September 2006 - 06:13 PM
Posted 19 September 2006 - 06:33 PM
As an Ammeter needs to be wired in in series into a circuit. If you wire it into your main battery cable, it'll only tell you what the battery is getting as a charge/discharge.
If you decide you want to know what the whole car is taking, youll have to get some good, thick wire, cut the two thick wires coming off your alternator, splice some of your wire in, run it up into your dash (routing if the wires is important, make sure they dont chafe on or get in the way of anything. Else you could get a massive short to earth) put that into one side of your Ammeter. Put another piece of your wire on the other side of the meter and run back down to the other end of the cut alternator wires. Just make sure the Ammeter can take 75A
Alot of fapping around if im honest, why not just stick with a volt meter?
Posted 19 September 2006 - 06:46 PM
who says you cant use a fuze!?!?
Heh. Well i might just leave it dead then. Its these 3 little chrome gauges that came in the dash but they arent wired in! i have the oil pressure wired in though... Then theres some other thing. Don remember if its oil temp or something else!
Thanks anyway!
Posted 19 September 2006 - 06:49 PM
Posted 19 September 2006 - 09:11 PM
A brief explanation of a shunt type ammeter is that you put the shunt (which is a large, low resistance, resistor) in series with the main power lines just like you would a traditional ammeter. The current flowing through the shunt creates a small voltage drop. The ammeter gauge mounted in the passenger compartment is actually a very precise and delicate volt-meter which monitors the drop across the shunt. In effect, you're wiring a relatively safe volt-meter inside the car.
