Steering Slipping, What Could It Be ?
#16
Posted 03 May 2017 - 02:49 PM
#17
Posted 03 May 2017 - 04:02 PM
Phew, glad it wasn't knackered splines
#18
Posted 03 May 2017 - 11:21 PM
Please everyone, remember that the pinch bolt for the column to rack joint is required to be checked for tightness at every routine service. That is because it is a real killer if ignored. It only takes 30 seconds with two spanners.
Also, if you have it apart, the rack and column must be aligned correctly as described in the manual. People have been killed after fitting steering column drop brackets without realigning the rack. Drop brackets which are not sufficiently stiff laterally or where the adjustment can slip (MOST!) are manifestly unsafe for much the same reasons.
The rack U bolt locknuts becoming loose by themselves is not all that common, They are supposed to be Nyloks.
#19
Posted 06 May 2017 - 10:33 AM
