Hi
My carb is leaking fuel, firstly im going to change the gaskets to see if this solves the problem other wise ill just get a new carb. Can anyone tell me how i can tell what carb i have (1977 mini 1000) or how to find out. I was asked this when i went to order the gasket set? I thought they where all the same. Im still a bit of a learner when it gomes to getting my hands dirty.
Many thanks
Blakie
Carb problems
blakie
, Sep 20 2006 04:40 PM
7 replies to this topic
Posted 20 September 2006 - 04:40 PM
Posted 20 September 2006 - 05:06 PM
Its probably a HS4 carb om a 998. you can get a rebuild kit from burlen fuel for about 35quid and that will make the carb like new, i did mine a few months back and it makes the world of difference.
Posted 20 September 2006 - 05:09 PM
its probley the choke pin at the bottom of the carb mine broke because my engine hit the bulkhead and bust the bottom
Posted 20 September 2006 - 05:13 PM
i got an old carb kicking about. if you need some bits i can send them (well bank account allowing. )
Posted 20 September 2006 - 06:04 PM
I may have cured the problem, thanks anyway. I will still get the kit you where talking about.
Posted 20 September 2006 - 06:26 PM
what was it, float jammed?
Posted 20 September 2006 - 06:47 PM
Float was fine, found a bipe leaking onto the carb which made it look like the carb
Still want help to identify all the spec of the car. Is there a web page that can tell me this?
Posted 21 September 2006 - 11:05 AM
Ok click on the link Iv'e put below, Find the identification tag on your carb, fill in the online form, click for results and off you go!!
Find out what carb you have!
Edited by Retro_10s, 21 September 2006 - 11:09 AM.
