Spark Plug Options
29 replies to this topic
#1 warning634
warning634
  • 489 posts
Posted 09 May 2017 - 09:11 PM
What other options of spark plugs are out there for the classic mini, apart from NGK, Champion and denso.
Cheers Kevin
#2 minimans
minimans
  • 411 posts
Posted 09 May 2017 - 09:14 PM
All manufacturers will have an equivalent plug. Just look on an interchange list. My question is why bother? the three manufacturers you mention make a good proven product.
#3 Dusky
Dusky
  • 5,322 posts
Posted 09 May 2017 - 09:40 PM
Brisk. I use them,dynoed them and had good results.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 09 May 2017 - 09:54 PM
Cheers Kevin
Very curious to know why you would want a make other than one of these three?
#5 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 09 May 2017 - 11:52 PM
Why? If it aint broke, don't fix it.
#6 Quincy Sparks
Quincy Sparks
  • 242 posts
  • Local Club: BHMC, MCR
Posted 10 May 2017 - 07:30 AM
From memory, Euro Car Parts stock Bosch plugs and at least one other budget brand whose name escapes me, but I've not used either.
#7 warning634
warning634
  • 489 posts
Posted 10 May 2017 - 08:32 AM
I'm having issues with my plugs fouling up when on idle on warm up. The engine was fully set up on the dyno, so the carb/fueling is fine. I was running bp8es and they where fouling up, so I fitted some hotter plugs bp7es. But I'm still having issues when it's cold, they foul up. Once up to temp I don't get issues. It's I have some events coming up a sprint and hill climb which wil mean a lot of waiting in a cue until my run, and I'm worried about getting to the start line and it's going to running rough. So I'm looking for other plugs or will a different plug gap help. Please what are your thoughts?
Kevin
Edited by warning634, 10 May 2017 - 08:32 AM.
#8 Midas Mk1
Midas Mk1
  • 5,779 posts
  • Local Club: S.U.N.M.C
Posted 10 May 2017 - 08:43 AM
I was getting fouling with 7's when cold and not driven flat out, fitted 6's as recommended on here and its fine.. (stg 4 1380)
A set of NGK's is less than £10 posted on ebay, so why get anything else?
Edited by Midas Mk1, 10 May 2017 - 08:44 AM.
#9 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 10 May 2017 - 09:03 AM
I'm real pleased the sixes worked for you. :proud:
#10 Readers14
Readers14
  • 439 posts
Posted 10 May 2017 - 10:11 AM
Looking to replace the spark plugs on mine.
Which is the correct NGK part number for 1275 with a HIF44?
I have seen:-
BP6ES
BPR6ES
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 10 May 2017 - 10:59 AM
I have seen:-
BP6ES
BPR6ES
If you haven't had it set up on a rolling road I'd go for the resister option. BPR6ES
#12 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 10 May 2017 - 11:06 AM
I have seen:-
BP6ES
BPR6ES
I have seen:-
BP6ES
BPR6ES
BP6ES for points(use resistor leads)
BPR6ES for electronic
#13 Dusky
Dusky
  • 5,322 posts
Posted 10 May 2017 - 12:54 PM
Because there are gains to be made over ngk.
#14 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 10 May 2017 - 02:20 PM
There really aren't mate.
#15 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 10 May 2017 - 02:28 PM
They stock bosch and beru which is the same plug. I'm running bosch in one of mine and they're fine.
Edited by Mrpeanut, 10 May 2017 - 02:28 PM.
