There really aren't mate.
With all respect, there are. I've posted my findings and dyno results before.
It's more than just raw power. Behaviour of the engine and drivability are a big factor too.
Only if you were testing some dodgy no-name plugs against a well known brand.
Between the well known makes there's little difference, NGK's are pretty decent.
Not really. NGK Vs brisk LGS and multisparks(true multispark plugs, not multi prong plugs).
When I get back at my parents house I can post all exact data again, should be on this forum somewhere..
However, I can say that with the LGS and multisparks cold running improved drastically, to the point where I didn't need choke anymore. Wich is especially helpful if you run a Weber with the cold start blocked like most racers do(prevents over rich mixture when you're cornering and braking).
Power outputs are roughly the same, some 2-3% differences but I don't consider that too important.
Torque curves were a tad longer and flatter on the brisks.
On blind testing 5/5 people found the multisparks the nicest to drive in a bit cammed engine.
