Mpi 1997 How To Fit A/c Requirement Signal To Mems 2J Mk104292 ?
1 reply to this topic
#1 bmv133
bmv133
  • 15 posts
Posted 12 May 2017 - 09:58 AM
Hi everyone,
After years of searching, I have managed and installed an air conditioning on my 1997 rover mini mpi
The systems runs perfectly but to finish the project I want to inform the mems 2j ecu mkc104292 when the a/c is running.
I know that in japanise mini, you can do it using black connector´s pins 35 and 19 as you can can see in attached file acjapan_cdxn980s.pdf (I suppose it´s refered to an mpi mini due to vin number)
On the other hand I found that not only for japanise minis, that is, mpi´s in general, use pins 19 and 35 for the same goal as you can check in attached file mems2jmpi_cdxn980s.pdf
And finally I found at https://blackbox-sol...help/SM072.html only information about pin 19 but nothing about pin 35
But I want to be sure before ... can anyone confirm my investigations?
I would be grateful for some information ....!!
Cheers !
#2 Myran
Myran
    Starting My Mini Up
  • 2 posts
Posted 27 December 2018 - 04:35 PM
Hi everyone,
Cheers !
Hello.
Great pic the
Do you think you can link to the hole manual.
Best regards from Stockholm // Lennart
-97 Rover Cooper MPI
