Hello chaps. I'm busting to go full steam ahead on my new shell to get it prepped and painted before the season turns too damp to do it, but i need a couple of welding jobs done. how much am i looking at paying for each of these, if i prep everything up to the point of welding (cut out rotten metal, fit panel/patch, weld-through prime, and tack in place)? Esentially i'm just looking forsomeone to come out and run some welds for me.
I need:
driver's wing replacement.
head lamp repair piece on other wing.
drivers Upper flitch panel bit around air vent (will be accessible after wing is removed)
This bit on both sides
(the bit in the door bin isn't the bit that indicates a problem with the subframe mounts- its just a direct hole to see the ground below.)
Any ideas on welding costs?
Cheers guys?
Welding prices?
OllyD
, Sep 20 2006 08:55 PM
2 replies to this topic
Posted 20 September 2006 - 08:55 PM
Posted 20 September 2006 - 09:55 PM
your from higham? I may be able to do it for you i am over in rainham but i dont get my welder back from my dads for a good few weeks but if you can wait i am more than willing to do it for you.
Edited by tomm, 20 September 2006 - 09:56 PM.
Posted 20 September 2006 - 11:02 PM
that sounds brilliant! I actually have a welder here with me, i just can't work the bloody thing! The only thing is that time is of the essence, since i've ideally gotta have it all done and dusted by the end of next week. If i supplied the welder would you be able to do it? What kind of price would the jobs cost in total?
Cheers!
