Hey gang! I'm in re-assemble mode on my Mk3 and came across a possible problem as I began fitting interior bits.
I noticed some lower dash rail flex from any up/down pressure on the steering column, and the flexing all seem to be
in the "flat" area under where the binnacle mounts, the plate that runs from behind top of center switch mounts opening
back to the firewall.
At first it appears the area has a bend/bevel to allow fitment of the binnacle, but now I'm worried it's just bent and
weak. -Should that area be flat, front to back? Any ideas on strengthening? Dash cards and vinyl won't have
any "meat" to them to stop this. I'm considering making aluminum plates to fill the openings, and maybe
2 small strips of angle iron under that flat area.
Your thoughts and recommendations would be appreciated--
