Whats The Difference Between A L/h And R/h Front Drum Hub
19 replies to this topic
#1 feybrand
feybrand
  • 1,247 posts
Posted 22 May 2017 - 07:03 PM
Hello
I'm rebuilding my car and it has front drums,i never thought to mark them when i dismantled them and now i have 2 front hubs sat on the bench and have no idea which is which..they look identical to me but a quick look on ebay shows people sell them as sided I.E N/S or O/S so how do i work out which is which.
I know the back plates are different as i have had to replace them and they have different numbers ..they arent currently fitted to the hubs.
#2 nicklouse
  • 18,696 posts
Posted 22 May 2017 - 07:07 PM
The grease nipple holes point one way.
Can't remember off the top of my head if it is forward or backwards.
I think forwards. Look in your Haynes manual.
Edited by nicklouse, 22 May 2017 - 07:07 PM.
#3 tiger99
tiger99
  • 8,584 posts
Posted 22 May 2017 - 10:28 PM
Yes, it is forwards. And, the steering arms point backwards if they have not been removed. There usually is no need to remove them.
#4 Rorf
Rorf
  • 866 posts
Posted 23 May 2017 - 05:52 AM
Maybe he is talking about the flanges? Fits both sides
The CVs though are RHS and LHS.
Edited by Rorf, 23 May 2017 - 05:53 AM.
#5 Spider
  • 15,136 posts
Posted 23 May 2017 - 06:00 AM
The Top Ball Joint Nipple is forward facing and the Lower, rear facing.
#6 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 23 May 2017 - 07:15 AM
The cv joins are not sided.
#7 Spider
  • 15,136 posts
Posted 23 May 2017 - 08:09 AM
Well actually, they are - once you take them from the box and fit it to say the RH side, then it's the RH one ;D :kiss: :P
#8 tiger99
tiger99
  • 8,584 posts
Posted 23 May 2017 - 11:47 AM
Yes, and from the point of view of wear it should always remain on the side where it was first used once it has done more than a few miles, even if all the parts around it are changed. Same with the drive shafts, although they are unequal and would not be considered swappable, unless you were using one of the things that spaces the pot joint out to use two short (equal) shafts.
In the case of the shafts, reversal would nearly double the peak to peak torque that the shaft would see in its life and, unless it was over-engineered, probably take it above the fatigue threshold. The effects of wear in the CV are more subtle but nonetheless real.
I would suggest that hub flanges probably can be interchanged freely, as the drive torque is actually taken by the clamping load on the cone, not the spline, but why would you want to swap them anyway?
Just thought I should throw that in lest someone inexperienced does swap his bits about, with disappointing results. I knew of someone who did that with the torsion bar suspension on a Moggy
thinking that he would undo years of settling. Well it did, for all of 10 minutes, till a double loud bang was followed by the sound of one of Issigonis earlier creations scraping along the ground, as both bars fractured in quick succession.
#9 hhhh
hhhh
  • 422 posts
Posted 23 May 2017 - 01:40 PM
That's weird, I swear my nips are both facing forward.
#10 tiger99
tiger99
  • 8,584 posts
Posted 23 May 2017 - 05:00 PM
All of mine were too. Maybe they do things differently in Australia? I know that certain parts such as early radius arms were different, and better.
#11 Spider
  • 15,136 posts
Posted 23 May 2017 - 06:18 PM
Curious. I'll check a hub later.
#12 AlexMozza
AlexMozza
  • 1,248 posts
Posted 23 May 2017 - 07:06 PM
Now your just being pedantic! 😂
#13 A-Cell
A-Cell
  • 1,610 posts
Posted 23 May 2017 - 07:47 PM
Absolutely correct MokeSpider. Top BJ grease nipple forwards facing, Lower BJ grease nipple rearwards facing. Steering arm 2 bolt holes on the top of the hub to get the correct orientation for LH and RH.
#14 hhhh
hhhh
  • 422 posts
Posted 23 May 2017 - 10:58 PM
I have about eight examples in my possession and every one has the nipples in the front both top and bottom. These are all Mk IV and older Canadian imports.
#15 nicklouse
  • 18,696 posts
Posted 23 May 2017 - 11:25 PM
as i thought
But a DISC hub does have them different top and bottom.
