hi i waz thinkin of buyin a stage 1 kit for my mini (1983 austin mini sprite 998cc its all standard) but i dont know what carb i need the list from the site(minisport) says HS6, HIF44 or HS4/HIF38 thanks
Carb Help
MTBBoy
, Sep 21 2006 09:22 PM
6 replies to this topic
Posted 21 September 2006 - 09:22 PM
Posted 21 September 2006 - 09:35 PM
Is that due to you not currently having a carb, or you feel you need an upgrade? Stage 1 kits dont really need a bigger carb to perform - a K+N in box filter or a cone filter is about as much as you need to get in the carb section, along with some tweaking of the idle and mixture screws.
Edited by nev_payne, 21 September 2006 - 09:37 PM.
Posted 21 September 2006 - 10:07 PM
if its a 998 of that age then you have a su hs4. anything bigger and it gets tricky to set it up right.
Posted 22 September 2006 - 09:57 AM
hif38 is also an option as its the same size as an HS4 but ha the flost bowl internally.
Posted 26 September 2006 - 08:34 PM
Thanks for your help
Posted 27 September 2006 - 07:38 AM
hi mate what you want to do is keep the carb on you have if its a HS4 or a HIF38 there the carbs you want to use on a 1000 so when you buy a stage 1 kit you will get an inlet manifold an cone type air filter an AAA needle and lcb exhaust manifold and an exhaust and you will need to get an exhaust/inlet gasket and what i would do is change all the exhaust rubbers?hi i waz thinkin of buyin a stage 1 kit for my mini (1983 austin mini sprite 998cc its all standard) but i dont know what carb i need the list from the site(minisport) says HS6, HIF44 or HS4/HIF38 thanks
Posted 28 September 2006 - 10:50 PM
Thanks for the tip mate
