As title suggests. My indicators and hazards stopped working, no clicking of relays or anything so now assuming the flasher units broken.
But where is it? Its a 1996 SPI. Theres 4 very similar looking yellow relays in the engine bay, and a big 7 terminal one under the steering column. But I worked out this big one was the for headlights as they didn't work when I took it out.
Cheers,
Craig.
Flasher unit location??
msisleman
, Sep 21 2006 10:34 PM
2 replies to this topic
Posted 21 September 2006 - 10:34 PM
Posted 22 September 2006 - 06:49 AM
The big, pink, 7 pink under the dash is the dim/dip relay.... the flasher ( think they are still in the same place on the SPI ) is behind the clocks, should be a round 2 pin. The hazard one is the square one next to the wiper motor...
However, as the hazard and flasher units work independantly, I suspect there is more likely to be a wiring problem in the indicator circuit rather than the flasher units (unless you are realy unlucky and both have gone at the same time) for both not to be working.
Posted 22 September 2006 - 02:17 PM
Sounds more like a fuse issue to me? So check the relevant fuses first.
