Alarm is a Toad A101CL with single point immobiliser. I was going to make an immobiliser loop with the wire that goes from the starter relay to the starter solenoid. (The thickish brown one with the red stipe i think.)
Would this be ok? If not anyone got any ideas of what else i could use.
Wiring in immobiliser
Dave the Rave
, Sep 22 2006 07:01 AM
2 replies to this topic
Posted 22 September 2006 - 07:01 AM
Posted 22 September 2006 - 10:04 AM
[/quote]
if you have an electric fuel pump you can always use a switch to kill it so if the car is (S****N) god forbid it wont get far and then cut out its another option just make sure you hide it well and dont tell anyone
[/quote]
Edited by ANDY J, 22 September 2006 - 10:04 AM.
Posted 22 September 2006 - 06:46 PM
No its not got an electric fuel pump. I was also thinking of using one of the wires to the coil for immobilisation.
The reason i raised the query about using the wire from the starter relay to the starter solenoid is that it is quite a thick wire and the immobiliser wires are quite thin. Wondered if i ran the risk of burning them out? Any ideas?
