what size and where do i get the bolts to fix the fuel pump back to my engine?
also the bolts to fix the oil filter housing to the engine aswell.
all help will be much deeply appreciated :)
Posted 18 June 2017 - 09:49 PM
Posted 18 June 2017 - 09:56 PM
fuel pump tends to be studs and nuts
http://www.minispare...ipe.aspx?1~6~51
oil filter there are some variations
http://www.minispare...ic/CHS2613.aspx
might be right.
Mini Technical Sections →
Problems, Questions and Technical →
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
