lots of info here.
http://www.turbomini...p?p=vt&tid=2995
Posted 11 July 2017 - 11:52 PM
As AC has already said the light weight alternators will struggle to cope under normal road conditions, and you'll find the battery is providing the missing amps below a certain revs until its drained, as the alternator wont be able to replace the charge quick enough. They appear to be doing the job for a short while until the battery is depleated or you have trouble starting. Take the revs up to 3000rpm and do a test on the totals amps and you can see if its a negative charge going into the battery.
As a example 4 100w Cibies would be 34amps on their own and a 12v coil is 4amps, standard 55w headlights is 9.2amps, side lights just under 2amps, brake lights 3.5amps. So you can see you need a big alternator to have any hope of charging a 12v battery.
To the original poster if you volt meter is accurate then at 15v your into the terrority of boiling off acid in a lead acid battery and a very short battery life and failure
Posted 12 July 2017 - 04:36 PM
Thanks for the replies guys!
Spent ages last night on it, checking over all the connections, everything seemed tight, just tidied up a few wires near the fusebox.
Now on idle its at 14v, and with the headlights on its still 14 when above 1200rpm, bizarre but its what I was needing!
Will have a thorough checkover at weekend though, and try load it up with stuff to see how it fairs!
Thanks ![]()
Posted 12 July 2017 - 07:07 PM
sounds like somthing was loose then.
Posted 14 July 2017 - 10:02 PM
High resistance ?
