Hello all, i still havent got the car running yet. Got a mechanic round the other day, he told me that the starter motor is not disengaging. I have since removed the sarter motor and discovered that the spring is knackered so mechanic was right it doesnt disengage!!!
Does ay1 have a starter motor kicking around that i can buy preferably around Northampton area looking at collecting ASAP, its for a 1275 metro engine the 1 without the solanoid ontop!
Otherwise anyone know how i take the starter motor apart its the part that engages into flywheel i need to take apart.
Any help would be great
Cheers all
starter motor
miniman207
, Sep 23 2006 04:27 PM
5 replies to this topic
Posted 23 September 2006 - 04:27 PM
Posted 23 September 2006 - 04:37 PM
also how do you tell if your engine requires inertia or pre engaged starter motor? whats the diference?
Posted 24 September 2006 - 08:57 AM
The one without the solenoid on top is the innertia starter but I'm pretty sure that all Metros should have a pre-engaged. Do you have trouble starting it. is it noisy? The springloaded part is called a bendix and you can replace it on it's own (if the spring's failed it's not repairable but can be replaced) but to be honest it's not really worth it as a whole exchange starter is about twenty five quid at any motor factors.
Posted 24 September 2006 - 09:31 AM
I got loads of inertia starters, and not too far away in Rugby...
Posted 24 September 2006 - 12:01 PM
any chance of popping over and grabbing a starter off you ASAP please guessworks?
how much would you want for it?
Cheer
Gaz
Cheer
Gaz
