Stick To The Road!
18 replies to this topic
#16 Rusty1182
Rusty1182
  • 389 posts
  • Local Club: Mini Allsorts
Posted 30 August 2017 - 07:06 PM
Set the ride height to standard.
Solid mount the front sub-frame.
Fit adjustable tie bars.
Use 165 section Yokohamas on 10" or 12" wheels with wheels no wider than 5".
For damping use either a set of KYB Gas Adjust or Spax or GAZ adjustables.
Set front toe-out to 1 mm.
Fit 1.5 degree negative camber lower arms.
On the rear set zero to -0.5 degrees negative with 1 mm to 2 mm toe in.
Ensure all suspension bushes are in good condition.
I hope this helps. If done it will give good road-holding combined with excellent handling.
Once done do not drive faster than you know how to .
Hi Cooperman   Could you explain why no wider than 5" alloys?
#17 Cooperman
  • 23,046 posts
Posted 30 August 2017 - 08:03 PM
The Mini Spares conversion kit is very good.
#18 Rusty1182
Rusty1182
  • 389 posts
Posted 30 August 2017 - 08:26 PM
they have two kits and are £100 diffrent in price
#19 Cooperman
  • 23,046 posts
Posted 30 August 2017 - 10:14 PM
I've not heard of any problems with either.
If it's for historic competition you need to check the regulations as 'original specification brakes'may be mandated.
