And the diameter of the pipe.In terms of length, depends on your rev range, and where peak power is, helmholtz calculation...
Side Exit Or Centre Exhaust
#16
Posted 29 July 2017 - 10:22 PM
#17
Posted 30 July 2017 - 08:12 AM
#18
Posted 30 July 2017 - 11:47 AM
New one on me, cheers
#19
Posted 30 July 2017 - 12:47 PM
Side exit is a must in an estate I find. the flat back sucks all the fumes forward otherwise.
Just out of interest, do people running centre exits find that they pull the fumes in as said? My friends stunk but I put that down to a exhaust leak
#20
Posted 30 July 2017 - 12:57 PM
yes and diameter,
practically the difference in lenth is not worth worying about, more of an issue would be the quality of the bends before and after the silencer, ideally they should be mandrel bent to keep the bore the same all the way through.
this is somthing I've put together for my K headed turbo, 2.25" up to the silencer, the holled silencer tube is the next size up so fits over the 2.25", and then the tail pipe is the next size up again and fits over the holled ip taking it to 2.5".
Posted 30 July 2017 - 10:46 PM
Just a bit of history for you.
