Thermostat Sandwich Plate
17 replies to this topic
#16 nicklouse
  • 18,697 posts
Posted 03 August 2017 - 09:48 AM
For what it's worth, in all my Minis and Mokes over the last 30 odd years, I've never had a By-pass Hose and Never drilled the Thermostat (which to some degree over-rides it's purpose). No issues other than the cooling system takes a little longer to fill.
but they will have the standard hole with wiggly thing in it
Yes and they are made that way.
there were/are some that do not have that hole with wiggly thing and that could cause issues.
#17 Spider
  • 15,142 posts
Posted 03 August 2017 - 10:22 AM
None that I've had.
Some have had the wiggly thing, and some haven't. I've not been too bothered to look or check.
The warmer / hotter coolant will always rise to the highest part that it can (thermosyphon), whether there is flow or not (ie, when the Thermostat is shut).
As I have said and my experience, I haven't had an issue.
#18 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 04 August 2017 - 01:32 AM
I like to drill and tap the water pump (assuming its a good pump) and head pipe and use a bolt to plug both, they can then be cut down and forgotten. No chance then of the thing leaking.
I either cut the giggle pin out of the thermostat if it has one or drill a hole.
Without a hole or giggle pin the engine gets up to temp quicker.
Its bonkers but every one is right, you can do what you like, without using a sandwich plate.
