No Compression On One Cylinder Help
19 replies to this topic
#16 Spider
  • 15,201 posts
Posted 08 August 2017 - 08:28 PM
Couple of suggestions:
- first check the valve seat very carefully. Chances are it will be OK
- before putting back on the road check the fuelling, as running lean will burn out exhaust valves
If I can also add, retarded Ignition Timing will also do it.
#17 AeroNotix
AeroNotix
  • 267 posts
Posted 08 August 2017 - 09:56 PM
Can you show any pictures? Interested in what a burned valve looks like (in case I see it in the future)
#18 Spider
  • 15,201 posts
Posted 08 August 2017 - 10:38 PM
This one was a result of the wrong distributor and retarded ignition timing coming from the wrong distrbutor
#19 richw911
richw911
  • 2,084 posts
Posted 12 August 2017 - 06:04 PM
#20 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 12 August 2017 - 10:58 PM
Took a bite right out of it!  :-)
That will definitely lower the compression......
