Surely not enough to damage the thread?But then you compress the exposed threads and the nut won't undo and there's no way you can hold the taper to wind it off the compressed threads.
hell yes easily.
Posted 08 August 2017 - 12:16 PM
hell yes easily.
Posted 08 August 2017 - 01:24 PM
Why shock waves?One of the problems with using U style is they send shock waves into the rest of the connected components, not good if the joint is especially tight and requires several hard blows with the hammer.
Thats why I only use the "U" style compressors now instead of the scissor ones
Posted 08 August 2017 - 01:59 PM
Why shock waves?
One of the problems with using U style is they send shock waves into the rest of the connected components, not good if the joint is especially tight and requires several hard blows with the hammer.Thats why I only use the "U" style compressors now instead of the scissor ones
I use this one :http://minispares.co...|Back to search
I thought you were referring to this style http://www.halfords....AyABEgLNYfD_BwE
Posted 08 August 2017 - 02:03 PM
Why shock waves?
no different to a scissor type. different languages.
in English when describing ball joint spliters scissor refers to the action (rocking on a pivot).
A U type is as NP has linked to. hateful things.
Posted 08 August 2017 - 02:55 PM
Posted 08 August 2017 - 07:36 PM
Posted 08 August 2017 - 07:38 PM
It sounds very much to me that the Nut (and possibly the Pin) got damaged from the Impact that would have happened when the taper released.
You'll do WAY more damage with a 50lb hammer than you could with a 50 tonne press. Impact and vibration can be extremely damaging, don't underestimate this.
I have both types of ball joint breakers, the scissor type that I use 95% of the time, It's a quality Sykes one that's I've had for over 25 years now. I only ever tighten it 'so far' then if it hasn't released, a tap on the back and it pops.
I also have a high quality U type (brand unknown) that is belted with a hammer, that one I've had for probably around 35 years and the shank of the tool is probably around 300 mm long and the U is fairly small. Easy to use and instant results, however, I don't reach for it first up as it ruins the rubbers, though in a pinch, they can be reused until replacement become available. I've also had a few shorter types of these tools and found them to be rubbish.
Posted 09 August 2017 - 12:05 AM
Were the ball joints genuine? I've used non-genuine ball joints in the past that only lasted two "cycles". I.e. one installation and one removal until the case hardening was stripped from the bolt. The last attempt to put the nut on started stripping the threads completely.
Posted 09 August 2017 - 07:18 AM
The 'U' type of splitter is known as a pickle fork in the USA. I have both types of splitter in the box but generally just reach for a pair of heavy hammers on any joint where you have access to both sides as I find it causes far less damage and is quicker...........But you need a good aim and use a dead blow for success.
Posted 09 August 2017 - 11:37 AM
Posted 09 August 2017 - 12:12 PM
Posted 09 August 2017 - 09:23 PM
Definitely don't remove the nut before splitting the ball joints! Otherwise when they finally crack parts can go flying..Thanks all, but it leaves me in some doubt.
To protect the thread and the hub:
1) Remove nut.
2) Nut in place with no stud proud of the nut
3) Nut in place with stud proud of the nut.
Posted 09 August 2017 - 10:07 PM
