This Girl Can ( Or Rather Can't!) Solve Light Problems.
Posted 16 August 2017 - 06:45 AM
I would like to try and sort it myself, so can anybody give me some ideas of what to try next please?
Posted 16 August 2017 - 07:37 AM
If you have fitted a new fuse box the next step would be to change the connectors onto the fuse box, I would replace these then check all of the earth points and make sure they are clean.
Posted 16 August 2017 - 07:54 AM
As above i would go through taking off at at a time and cleaning them if possible, or terminating new ends on. Old wiring will be correded and no doubt be covered in engine gunk etc. So strip back til you get clean metal and reterminate. Make sure all connections are nice and solid making good contact.
Posted 16 August 2017 - 08:09 AM
If you need someone to take a look and give you some pointers let me know!
I am in West Yorkshire, and know a little bit about Minis
Posted 16 August 2017 - 08:23 AM
I think I'd be checking if the derustificationing disturbed any earth points, or melted any wiring. Also look at the connections on the starter solenoid.
