Mini Overheating While Driving But Cools Down When Stationary
Best Answer minitalia1275 , 04 September 2017 - 09:16 AM
Just to let you know that I have resolved the problem. I replaced the ht leads and adjusted the timing from 20 degrees to 10.
It is still very hot here but my Mini is no longer overheating.
Thanks to all for the advice. Go to the full post
17 replies to this topic
#16 imack
imack
  • 2,205 posts
Posted 22 August 2017 - 03:59 AM
I think I had this problem many years ago of engine running hot when driven/under load but temperatures normal at idle, it was the plastic impeller loose on the water pump.
If I ran the engine from cold with the heater hose disconnected from the heater valve and revved the engine coolant would come out of the valve with force.
Do the same thing with the engine at running temperature and the coolant would dribble out of the valve where the impeller was becoming a loose fit on the pump shaft when hot.
If you try this, add a length of heater hose to the heater valve and the other end of the hose into a bucket then you can reuse the coolant and not make the mess that I did!
Thanks. Did replacing the water pump to resolve the problem?
Yes, replacing the pump cured my problem, but check your water flow 1st with the engine hot and cold as mentioned above.
#17 minitalia1275
minitalia1275
  • 98 posts
  • Local Club: MiniFriendsTorino
Posted 04 September 2017 - 09:16 AM   Best Answer
#18 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 05 September 2017 - 08:59 AM
If it was sitting for several years, the bottom of the rad maybe silted up ... reverse flush it to try and shift some.
