I'm Beginning To Hate Vw Boras.
Posted 20 September 2017 - 11:28 AM
Posted 20 September 2017 - 11:36 AM
most likey the antiroll bar bushes. top tip when replacing is to fit new bush then use the rear calliper bolt to pull the bracket into the subframe then remove and tighten fully with the original. the bolts are very short and with a new bush it can be very hard to get the mounting bracket close enough to the subframe to thread the bolt in.
Posted 20 September 2017 - 11:44 AM
You don't say if its front or rear. Did the suspension fix include replacing the drop links?
Posted 20 September 2017 - 01:17 PM
Posted 20 September 2017 - 03:44 PM
Front lower arm bush? (Console bush)
Those are a total ******* for going on many VAG cars, they're not super-simple to replace either so get left until totally mullered.
Posted 20 September 2017 - 06:21 PM
Maybe totally unrelated but I had this on a Focus, the most annoying rattle. Took it back to where I got it from and they changes the drop links and ARB bushes and it still did it. Turned out to be the wheel trims they had fitted rattling about, put some original Ford ones on and all went quiet.
Posted 21 September 2017 - 12:26 PM
I had a problem on a Vauxhall Vectra B where there was a clunk at the front somewhere, only when going over rough roads, turned out to be the N/S CV joint.... after replacing every bush and a complete suspension system...
Posted 01 October 2017 - 07:03 AM
