Looking To Get My First Mini!
9 replies to this topic
#1 m1ikey7
m1ikey7
    Starting My Mini Up
  • 2 posts
Posted 20 September 2017 - 06:52 PM
Hi everyone,
Ever since i was very young i have wanted a classic mini, i have now finnaly got the go ahead to get one. I am looking for a mini that doesnt have two much work, im fine with doing interia work and cleaning out engine. I am able to do some levels of welding but it would be much better if the subframes were okay and it was more like floor pannels, sills, boot etc. I would like it to be running and easy to get back on the road so i can use it whilst doing work on it as i dont want the engine just to get left there. My budget is £1000, im sorry if I seem picky. I dont mind if its a 1000 or a 1275.
Many Thanks
Mikey Jones
#2 greenmini1275
greenmini1275
  • 348 posts
Posted 20 September 2017 - 08:10 PM
You might be able to get one for that price that needs complete restoration, but I doubt it would be road worthy. £1500, might get you one safe to drive on the road.
#3 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 20 September 2017 - 08:21 PM
I agree you are going to need some more money. 1000 if basket case project now a days
#4 m1ikey7
m1ikey7
    Starting My Mini Up
  • 2 posts
Posted 20 September 2017 - 08:40 PM
okay thank you for you advice, I will keep looking and try and get something at around that price that needs the least amount of work possible.
#5 Cooperman
  • 23,050 posts
Posted 20 September 2017 - 09:06 PM
The problem is that a Mini for around £1500 is likely to need a lot of body restoration which will, in turn, mean a re-spray will be needed.
Classic cars are not cheap. Low purchase price equals much restoration and hence much money.
#6 mab01uk
mab01uk
  • 11,834 posts
Posted 20 September 2017 - 10:50 PM
Sadly the days of cheap road worthy Minis with an MOT are over and as already said any bargain priced Mini today will need lots of work, time and money spent on restoring it. You might be better buying something like a small hatchback like a Fiesta for under a £1000 as your first car and then saving up to buy a good Mini in a couple of years.
#7 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 21 September 2017 - 09:10 AM
I think you will struggle at £1000. But my advise is go for the best shell you can get and avoid paying extra for other people's mods that may not be your thing, for example Don't get drawn in by big wheels and carbon fibre bonnets, all that can be done later. On a tight budget you can't afford the "bling".
#8 Cooperman
  • 23,050 posts
Posted 21 September 2017 - 12:28 PM
A lot depends on how much you can do yourself.
For example, a low price Mini may well need an engine rebuild. DIY cost could be around £850, but if the labour charge is added it would be considerably more and then machining cost would need to be added.
Then there is the gearbox ..... .
#9 Zach P-D
Zach P-D
  • 444 posts
Posted 21 September 2017 - 12:38 PM
Honestly, for a sound mini as you describe you'd want to double your budget and add a bit. 2.5K ish should be getting you a MOT ready/MOD't Mini that will be safe to drive on the roads.
#10 some1158
some1158
  • 369 posts
Posted 22 September 2017 - 05:38 PM
This guide may help you avoid some of the worst problems: https://www.yumpu.co...ni-buyers-guide
Also look out for oversills (see the pinned thread for more info...)
