Can someone confirm if the battery negative cable is attached to boot floor on a captive nut? Looks like it is simple bolted into place but I assume the nut it welded to underside of floor...
Mpi Battery Negative Cable
jamesmpi
, Oct 01 2017 03:34 PM
4 replies to this topic
Posted 01 October 2017 - 03:34 PM
Posted 02 October 2017 - 12:11 PM
If no-one replies I'll get a couple of pictures when I get home tonight.
Posted 02 October 2017 - 06:34 PM
Hi the bolts can understandably be very stiff, a bit of wd40 should help, and it would most likely be an imperial size.
Posted 02 October 2017 - 07:17 PM
Cheers peeps. Little job for the weekend
