Rear Drum Screw Stripped
26 replies to this topic
#1 bob540
bob540
  • 357 posts
Posted 01 October 2017 - 07:05 PM
I went to take off my rear brake drum today and I stripped one of the screws holding the hub on. I tried using a rubber band, using a flathead driver, tightening a bit first before loosening but I couldn't help but strip it. What's the best approach to get it out?
My instinct is to drill it out but I've never done it before so I'm a bit unsure of how to do it correctly.
#2 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 01 October 2017 - 07:15 PM
Drill it out, use a 5mm drill in the centre of the head of the screw... Just get the head of the screw off
then remove the drum( you may need to back the adjuster off, I then use a hammer too
then finally unscrew the remaining stud
Edited by cal844, 01 October 2017 - 07:17 PM.
#3 wile e coyote
wile e coyote
  • 1,230 posts
Posted 01 October 2017 - 08:26 PM
The screwhead doesn't look too knackered - if you've got an impact driver give that a go with the aid of a lump hammer....
#4 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 01 October 2017 - 08:36 PM
I get quite a few of these in the mower trade, the screws which hold the bottom blade to the soul plate. I wouldn't drill it just yet. It's quite soft and a decent non rounded-off punch will dig in and make a good nick, sufficient to get enough purchase to punch it round
#5 bob540
bob540
  • 357 posts
Posted 01 October 2017 - 08:57 PM
Don't have an impact driver unfortunately, was actually meant to get one a couple of weeks back but bought something else instead, kicking myself now lol. Will try a punch and if that doesn't work I'll probably try drilling it
#6 Homersimpson
Homersimpson
  • 835 posts
Posted 01 October 2017 - 09:23 PM
If you have a large cross head screwdriver try hiting the it whilst turning, this may loosen it off.  If not then try a punch as suggested above.
#7 Cooperman
  • 23,324 posts
Posted 01 October 2017 - 10:40 PM
A sharp centre-punch and a hammer will almost certainly get that screw out.
In fact those screws are totally unnecessary and the wheel studs prevent the drum from coming off when the wheel is fitted.
#8 bob540
bob540
  • 357 posts
Posted 01 October 2017 - 11:11 PM
I read a post of yours on earlier today where you mentioned that these screws are essentially useless and to just put some copper grease in between the drums and the alloys to prevent them binding so that's exactly what I'm going to do when I put everything back together. I'm going to try a punch tomorrow evening after work so hopefully that'll work
#9 Ethel
  • 26,057 posts
Posted 01 October 2017 - 11:23 PM
Do you have a Dremel? Another option is to cut a slot.
#10 Rorf
Rorf
  • 866 posts
Posted 02 October 2017 - 05:56 AM
Before loosening the other star screws on the other wheels squirt a little bit of WD40 to release the rust.
#11 bob540
bob540
  • 357 posts
Posted 02 October 2017 - 06:37 PM
Update - I've made it worse :D Went at it with a centre punch this evening but it is just not budging, the head is pretty much mangled at this stage so I think I'll have to drill it unless someone has another idea?
@Ethel I do have a dremel but I think even if I cut a new slot it would probably just strip again. It's as if the screw is made of lead!
@Rorf, thanks for the advice, I think something like plus gas is a better option for penetrating rust though. Wasn't sure if spraying lubricant onto brakes parts was the best idea either?
free photo uploading site
#12 Swift_General
Swift_General
  • 871 posts
Posted 02 October 2017 - 06:49 PM
I think it's at the point where I would just drill it out if it were me. You have the drums with built in spacers so should be left with plenty of thread to work with with the drum off.
#13 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 02 October 2017 - 06:53 PM
Drill the head off will take 5 mins
#14 Cooperman
  • 23,324 posts
Posted 02 October 2017 - 06:54 PM
Normal WD40 is not a penetrating oil.
#15 bob540
bob540
  • 357 posts
Posted 02 October 2017 - 08:11 PM
Ok going to try drilling it out tomorrow evening, thought I had steel bits but I can't seem to find them now.
