Doorstep repair
Posted 27 September 2006 - 09:55 PM
Only I’m not sure weather I will need to brace the door opening or not, as the only bit of rot I can find on the inner sill is a small hole the size of a 2p coin and the outer sill is only a few months old, so I pretty much sound.
Any help would be much appreciated, as I don't rally want to screw it up and have one side longer than the other etc.
Cheers,
Posted 27 September 2006 - 09:58 PM
Better safe than sorry
Posted 27 September 2006 - 10:04 PM
Posted 27 September 2006 - 10:06 PM
look on Guesswork page and pics of petal i think he used something like that
Posted 27 September 2006 - 10:32 PM
The quick amongst you will notice that a Flip Front is on the adgenda, and also some serious panel replacement because of rot... A home made jig (bit of wood ) to hold the hinge panel in place while trying to rebuild the door step and floor, fortunately the other side was not as bad ( didn't have to replace the doorstep !! )
Edited by 1984mini25, 27 September 2006 - 10:30 PM.
Posted 27 September 2006 - 11:10 PM
Posted 28 September 2006 - 05:26 AM
BUT make sure you dont jack the car up , I can not stress this enuf , if you jack it up and then weld the sills ,inner sills or doorstep you WILL get disstorsion .
the safe way to do it is to drive your mini forwards onto a ramp (only on the side you are doing)
then jack the car at the rear and put the other ramp under the rear wheel (facing as if you reversed it up )
the mini can not roll off and it is suported corectly .
