Hello.
I currently upgrading my brakes from drums all round to 7.5 disks on the front with a servo assist unit on my 1984 Austin mini sprite build.
I have installed a servo system and pedal box from a 1989 mini.
Question 1: Is the 1/2inch nut arrowed to adjust the clearance between the servo push rod and the master cylinder?
arrow.jpg 33.48K 13 downloads
Question 2: Should i set this just with the pedal feel?
Question 3: The crank assembly (pictured no.19) is resting against the bulk head when the pedal is released. Should there be a bump-stop either on the peal or on the bulkhead? or should the brake light switch be adjusted till there is no longer a clearance issue?
imagejgy.jpg 37.14K 4 downloads
