Right then ive got a knocking when i release my accelerator pedal and reverse fast. I think the bushes are buggered on my engine stabalisers or something like that because it sounds like its knocking as the engine tips forward. Am i right in thinking this or could it be something else??
Knocking when let off the accelerator!
Curry
, Sep 29 2006 11:48 AM
6 replies to this topic
Posted 29 September 2006 - 11:48 AM
Posted 29 September 2006 - 11:53 AM
check al the negine steady bushes. could also be the engine mounts.but it could also be the carb knocking on the bulkhead(if it has one) but that could be due to the bushes being worn!!
So yeah check all your bushes out(jammy's fav past time)
Posted 29 September 2006 - 02:10 PM
check for a crack on the floor plan under the carpets where the subframe mounts to the floor
Posted 29 September 2006 - 04:37 PM
Check the tear drop mounts on the front of the subframe and the tower mounts. I had a rocking engine for ages and it was because the engine mount rubber had parted from the metal. Tricky to check but worth replacing if they are old.
Posted 29 September 2006 - 07:24 PM
i had the same problem, new bushes won't sort it out if you've been using it like that for a while, one of my engine mounts had split in half. i'd get them checked if i were u
Posted 29 September 2006 - 07:29 PM
do what i do turn the radio up so u cant hear it
Posted 29 September 2006 - 07:39 PM
or you could get i fixed and have a nice driving mini...
