Metro Ball Joint Lock Tabs On Minisport Alloy Hubs.
Posted 29 October 2017 - 05:35 PM
Just about to do the final assembly on the front end of the GTM. I have Minisport alloy hubs that use the Metro ball joints top and bottom. Can anyone advise on how to correctly fit the lock tabs? There appears to be no flat to fit the big washer over on the hub so I'm stuck a bit. Not going to contact them about it obviously!
Posted 29 October 2017 - 05:50 PM
use some thread lock.
Posted 29 October 2017 - 06:17 PM
Posted 29 October 2017 - 06:30 PM
Also, just be very careful which ball joints you use.
I've found there's many Metro Ball Joints out there that don't have enough swivel angle in them to use in a Mini. This would result in broken ball joints.
I can say the QH ones don't have enough angle but the Delphi ones do.
Posted 29 October 2017 - 06:53 PM
Posted 05 April 2024 - 05:04 PM
Posted 05 April 2024 - 06:51 PM
I've been using 243 on my regular Mini Ball Joints for some time now. As long as both threads are clean when you apply it, it'll work fine. I use paint thinners to clean them.
If you are unsure, assemble a set and leave them overnight, then undo one. If you do this, be sure to disassemble, clean and reapply the 243.
