Temperature Sending Unit
20 replies to this topic
#16 Agus1601
Agus1601
  • 150 posts
  • Local Club: La Tribu Mini
Posted 19 November 2017 - 02:09 PM
Hehehe right I amin Argentina... But I buy everything on main centers like minispares and minisport.
I have a very new electrical system, not a mini one. It was done so as to fit lots of things
Having same problem with my other mini, but it has de 2 clock dial
Thanks a lot guys!
#17 splintercat
splintercat
  • 616 posts
Posted 19 November 2017 - 07:54 PM
Thanks a lot guys!
LM7810 is only the code for Maplins .....google it and yu should be able to pick up an equivalent three pronged solid state voltage regulator from any generic electronic/electrical hardware shop ...even in Argentina push comes to shove ...pay the postage and i'll try and send you one   :)
#18 nicklouse
  • 18,998 posts
Posted 19 November 2017 - 08:55 PM
Thanks a lot guys!
and you have a Haynes manual? if not please get one. they do cover just about everything. including the voltage regulator and position.
#19 Agus1601
Agus1601
  • 150 posts
Posted 19 November 2017 - 10:04 PM
Thanks a lot guys!
I have a lot of haynes manuals... and knew it had a voltage regulator there hehehe
I seen it before but why cant it affect the temperature if the temp gauge is not in there at all
#20 mini13
mini13
  • 3,811 posts
Posted 20 November 2017 - 02:46 PM
a quick 101 on how the system works,
the gauges are fed from 10v from the voltage stabalizer, although its not a stable 10v it actually pulses a bit as its a bimetalic strip, but should average out to 10v.
the gauge is shorted to ground via the temperature sensor the resistance of the gauge and the sender are matched to give the right reading so for diferent years and difernet manufacturing areas there was different gauges and due to that senders. innocentis in particular are hard to find senders for.
#21 Agus1601
Agus1601
  • 150 posts
Posted 25 November 2017 - 11:41 AM
Hi Guys! How can you notice if the water pump is not working good? Because I think maybe also I have that issue.
Agustin
