Castrol Magnetec Engine Oil With Series A Engine?
engine
17 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 17 November 2017 - 01:49 PM
Hi Guys,
Quick question, is it alright to use Castrol Magnetec oil with a Series A engine?
I figure that perhaps the magnetic particles might help to pull away tiny metal fragments when the oil is drained. Though it comes in 10w-40, no 20w-50 versions. Perhaps one could add a small bit to the engine during an oil change? (say 4L 20-W50 and 1L castrol magnatec)
#2 imack
imack
  • 2,195 posts
Posted 17 November 2017 - 02:13 PM
Personally I'd stick with a good quality classic 20/50 such as millers, castrol classic or valvoline vr1 and change it regularly.
#3 nicklouse
  • 18,679 posts
Posted 17 November 2017 - 02:23 PM
Hi Guys,
it will not be good for your gearbox if a manual.
#4 CityEPete
CityEPete
  • 3,920 posts
Posted 17 November 2017 - 03:05 PM
I put some in a mini twenty years ago, it was the only oil tight mini I've owned, it leaked everywhere and never stayed oil tight again!
20-50.
#5 nicklouse
  • 18,679 posts
Posted 17 November 2017 - 03:17 PM
the main issue is lack of any Zink package for the gearbox.
#6 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 17 November 2017 - 03:53 PM
Righto. I'll stick with 20w-50.
Cheers!
#7 Spider
  • 15,077 posts
Posted 17 November 2017 - 07:23 PM
Many moon ago Castrol was a client. At that time they were advertising their motors oils as having 'Liquid Tusngsten' . While on their site one I was able to speak with one of the chemists as this had me curious as to how they could make Tungsten in a liquid form, he merely chucked and said it was Liquid Bull Sh!t.
While I have found most Castrol Products over the years to be good, I don't feel any of the Motor Oils suit the Mini engine & Gearbox.
#8 dotmatrix
dotmatrix
  • 441 posts
Posted 17 November 2017 - 08:49 PM
first of all I am no oil expert. I use magnatec for my newer engines (k-series and that rover 75 diesel) where its very good and minispares classic oil, gulf classic or castrol classic for my standard a-series engines.
I know that 20w-50 is the most common viscosity of oil to use in the a-series I would not think twice about using 10w-40 if I could find one with a suitable amount of zinc.
I have stopped using castrol classic even though I have been using it for years as I found out that the cheap minispares classic 20w-50 oil has lots more zinc in it that the castrols inadequate 800ppm. gulf classic also has a suitable amount.
for my racing a-series I use a castrol based racing oil called racing IVI which is a synthetic 25w-50 oil with 1800ppm of zinc. I am very pleased with this oil, no blue oil burning smoke when the oil is hot and no worn through main bearings.
anyway, this is my experience with oils :-)
#9 gazza82
gazza82
  • 3,018 posts
  • Local Club: TMF+
Posted 18 November 2017 - 09:32 AM
Duckham's is back ... :-)
A few a-series owners I know use Valvoline.
#10 Mervyn
Mervyn
  • 256 posts
Posted 18 November 2017 - 12:25 PM
I use Millers CTV 20/50
it's good stuff
Merv
#11 nicklouse
  • 18,679 posts
Posted 18 November 2017 - 03:00 PM
Cheers!
if it does not have suitable ZDDP package it is as useless as the 10-40 with out a suitable ZDDP package.
https://en.wikipedia...dithiophosphate
#12 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 18 November 2017 - 03:53 PM
Out here in Malaysia its hard to come by much choice. Im using Shell HX3 20w-50. The others that are readily available would be Caltex, Penzoil, Liqui Moly (insanely expensive), Elf and Castrol and some other brands I havent heard much of (for 20w-50 at least).
Edited by BaronVonchesto, 18 November 2017 - 03:57 PM.
#13 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 18 November 2017 - 03:55 PM
Anyone used Bosch 20w-50 before? Its a fair bit cheaper than the Shell I use.
#14 Cooperman
  • 23,322 posts
Posted 19 November 2017 - 12:13 AM
After realising that a 20w50 oil is needed the only other question is whether the zddp (zinc) level is high enough. If it is not then the gearbox will suffer.
#15 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 19 November 2017 - 12:37 AM
i doubt any of the oils here will have much zinc or phosphorus. will need to find an additive
