Spark Plug Misfiring But Not Faulty
Posted 28 November 2017 - 12:38 PM
I then put the faulty plug in another cylinder and it was running perfectly.
I don't understand why the plug was faulty on one cylinder but was running perfectly on another
Posted 28 November 2017 - 12:53 PM
do a compressin check,
also check the val clearances on that cylinder in case the tappets have come undone.
Posted 28 November 2017 - 01:25 PM
Check all your plug gaps.
Whilst you were running on 3 cylinders , the fourth spark plug was being coated with petrol and the spark tracked to earth. When you put this 'wet' plug in a nice warm and 'dry' cylinder it was able to fire and clear the misfire.
Probably nothing seriously wrong but it might indicate you need a service or just new plugs.
Posted 28 November 2017 - 01:27 PM
What you might find is the plug wasn't good enough for a cold start (breaking down) but when put in an already warm cylinder it was producing enough of a spark to keep that cylinder running (which had warmed up a bit from your earlier attempt at starting the car). I suggest it goes in the bin.
Posted 28 November 2017 - 01:44 PM
Very cold this morning and I most probably gave it too much choke, soaked the faulty plug and ran rough all morning until I replaced the plug.
The plugs were newish, about 500 miles but I will replace all four
Posted 28 November 2017 - 02:12 PM
As a "belt and braces" you may also want to check the distributor cap as well for hairline cracks around the contact where the faulty plug is connected to.
Posted 28 November 2017 - 02:22 PM
The HT leads are new.
Posted 28 November 2017 - 02:29 PM
Ive always found mini love new plugs, and when ive had one foul its for the bin. Not worth the effort of trying to clean it as there so cheap.
Posted 28 November 2017 - 03:36 PM
Thanks for the advice
Posted 28 November 2017 - 04:40 PM
Thanks for advice. I have checked the compression and it is the same in all four cylinders.
It was 'VERY COLD' in Italy ?????? !!!!
Blimey, just looked. It's as cold as here.
Edited by rww, 28 November 2017 - 04:56 PM.
Posted 28 November 2017 - 05:56 PM
Yes, it was freezing this morning. Snow is forecasted for the weekend. We are not too far from the Alps, I already have the snow tyres fitted on the Mini but I never use it in the snow
Posted 28 November 2017 - 10:40 PM
Noticed yesterday after getting my mini back from the sprayer how it was running HORRIFICALLY. Sounded as if it was only running on two... Realy lumps. Got about 100m pulled over and checked leads.... After a few mins of idling and a few yanks of the throttle cable with plenty of choke it cleaned up. But i reaaaly felt like i had a problem...
Posted 14 January 2018 - 04:20 PM
So far I have fitted new plugs, HT leads distributor cap. Carb and timing spot on. Compression perfect.
Posted 14 January 2018 - 08:52 PM
It proves Miglia's point...they do like new plugs !...did you gap them all ? have you checked the valve clearances ?
New condensor fitted ?
Wondering if its the grade of plug with it being colder air than 'normal'....
On Std 998 we use NGK BP5ES, not sure what plugs you run ?
Posted 14 January 2018 - 09:29 PM
Just thinking outside the box, when you say it's wet, are you sure it's wet with petrol. What's your oil consumption, I'm thinking about a leaking valve stem oil seal?Unfortunately the problem hasn't been resolved. New spark plugs fitted but still fouling on one cylinder and running on three. When I fit another dry plug, all is fine.
