Small Oil Leak Here - Advice
engine
8 replies to this topic
#1 ryomini
ryomini
  • 583 posts
Posted 03 December 2017 - 12:27 AM
Hello
almost 10 000 kms since the rebuild.  Have noticed a small oil leak, appears to be coming from this area around the clip, on the outside of course, what does it indicate, should I be worried, what action should I take,
thanks for your help as always
#2 Rorf
Rorf
  • 866 posts
Posted 03 December 2017 - 05:29 AM
Leaking here is usually from the crankshaft seal, which requires removal of flywheel to replace. If it is very slight I would leave as is.
#3 Spider
  • 14,895 posts
Posted 03 December 2017 - 07:23 AM
.....should I be worried, ........
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 03 December 2017 - 10:50 AM
Did you replace the primary gear oil seal on the rebuild and what was the condition of the primary gear?
Edited by Northernpower, 03 December 2017 - 11:16 AM.
#5 ryomini
ryomini
  • 583 posts
Posted 04 December 2017 - 08:10 AM
OK thanks, I thought so, the lovely orange seal, no it's just a tiny drop occasionally, but here in Japan at the car tax inspection they fail you for that kind of thing. I'll let it go for a bit and check some more that it's not coming from somewhere else and flowing near that area. Thanks for the pictures too :)
#6 ings
ings
  • 201 posts
Posted 04 December 2017 - 02:32 PM
i have also a leak there and the area is perfect to clamp a small towel under the pin
just to keep your parking oil free. But someday id need to be fixed.
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 04 December 2017 - 07:44 PM
have you got this protecting the seal
http://www.minispare...px|Back to shop
#8 Spider
  • 14,895 posts
Posted 04 December 2017 - 08:34 PM
From my experience, if it is the Oil Seal, not all Oil Seals are equal.
I've had mostly good success with these;-
http://www.minispare...05.aspx|Back to
But, I believe these are better (though I haven't tried them);-
Check the bushes in the Primary Gear are not worn and also check that it's not oil weaping in via one of the bolts or studs.
<Edit: While not a likely cause, but best to check all the same, be sure the Crankcase breathers are not choked. >
Edited by Moke Spider, 04 December 2017 - 08:37 PM.
#9 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 04 December 2017 - 10:05 PM
Fitted the 1992 onwards seals to all our A+ engines(one is a 1989, 2 are 1993/4, all carb'd) all these engines have oil leaks, of varying degrees but a leak is a leak imo
