Windscreen Washer Hose Route
2 replies to this topic
#1 jameslearwood
jameslearwood
  • 525 posts
  • Local Club: ALL ALONE
Posted 09 December 2017 - 07:12 PM
Hey
1993 rover Rio with washer bottle in boot.
Pretty simple but totally forgot where the hoses ran and can't seem to spot any trace of where they went. Rather put it back as original
I know older model had it all in engine bay and newer models ran inside across the roof.
So it ran inside but all my head lining is intact so can't see anywhere it would of went i was assuming it went along the floor but can't find a clean run.
Where does it enter from the boot into the interior?
Where does it cross through the bulkhead?
#2 Marco1972
Marco1972
  • 822 posts
Posted 09 December 2017 - 07:23 PM
Hi
It goes up the rear C post along the roof and down the front A post and out through the bulkhead through a grommet
Easy job if the headlining is removed , on the mini line we used to put a small bolt in the end of the washer tube this gave it a bit of weight and helped it along through the body
Mark
Edited by Marco1972, 09 December 2017 - 07:27 PM.
#3 jameslearwood
jameslearwood
  • 525 posts
Posted 09 December 2017 - 08:31 PM
Brill cheers I must of pulled it out through headlining should be interesting getting it back through
