Spi Fuel Pump Wiring
7 replies to this topic
#1 alrg500
alrg500
    Starting My Mini Up
  • 2 posts
Posted 09 December 2017 - 07:46 PM
Hi, recently got a SPI Cooper that was half restored. having trouble with the fuel pump running. there is power to the output side of the inertia switch but power to both wires is lost between that and the connector at the tank, are there any connections behind the dash? where do the wires run from front to back?
The pump and car runs fine when a wire is run from the inertia switch to the pump and another to earth
#2 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 09 December 2017 - 10:01 PM
Have you tried removing the inertia switch and bridging the contacts for continuity?
#3 alrg500
alrg500
    Starting My Mini Up
  • 2 posts
Posted 09 December 2017 - 10:25 PM
Thanks for the reply. Yes we have power past the inertia switch and confirmed that is working fine, it gets lost somewhere between the switch and the pump connection.
#4 gazza82
gazza82
  • 2,919 posts
  • Local Club: TMF+
Posted 10 December 2017 - 01:43 PM
Loom is probably under the carpet.
#5 genpop
genpop
  • 475 posts
Posted 11 December 2017 - 06:24 AM
No, loom is not under the carpet, it's in the roof.Disconnect the indoor light, the pump and all rear lights.Then solder an other wire to one of the connections. Now you can pull the complete loom to the foot compartement on the left side of your mini.You will see the loom running from the center of the dash to the left door hinge and then into a hole upwards to the roof.
Second possibility is to pull part of the loom out of the hole for the indoor light and check if the wire for the pump keeps current up to here.If yes you only have to pull the loom up to here.Solder a new piece of wire to it and pull it back to the rear.
#6 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,129 posts
  • Name: Sean
Posted 11 December 2017 - 02:15 PM
Have you continuity checked both wires?
#7 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 11 December 2017 - 10:46 PM
 That's a new one on me. All the SPi's I've had the pleasure of working on, the rear loom runs along the passenger side floor. There's a clearance section in the cross member and the floor channel is slightly deeper than the others.
#8 genpop
genpop
  • 475 posts
Posted 12 December 2017 - 05:20 AM
@ Sprocket
sorry, with my 92 spi ,it is like that. Possibly one of the owners had changed it before. And i forgott : do'nt forget to disconnect the wire for the rear shield heater!
