starting problem..
Posted 01 October 2006 - 03:03 PM
Got a bit of an odd problem.
The mini sometimes (after its been stood for a day or so) takes ages to start. It turns over, and after a while it splutters then catches.
If its just been run, then it burst straight into life.
I wonder if it could be the battery as, its about 1 volt down I think. Could that be the issue?
Could it either be fueling, im using the standad mechanical pump.
I replaced the leads, rotor arm, cap (its got luminition elec ignition) in August so that all should be fine.
Any ideas people?
Cheers Ad
Posted 01 October 2006 - 03:06 PM
Are you using enough or too much choke?
Have you another battery to try?
Posted 01 October 2006 - 03:10 PM
Did it run ok before u replaced the above?
thanks for the reply Jordie
It used to run fine a year ago before I took it off the road!
Ive been playing with not using any choke at all, it seems to help, so maby its running far too rich.
I dont have a spare battery unfortunatly, im tempted just to buy one as the one in the car is 6 years old.
Posted 01 October 2006 - 03:16 PM
Let us know how you get on.
Posted 01 October 2006 - 03:41 PM
Will give it a go!
cheers Ad
Posted 03 October 2006 - 12:27 AM
Posted 03 October 2006 - 05:02 AM
Posted 03 October 2006 - 12:03 PM
I hadnt thought about the engine earths, I better check, thanks.
Do you use the vaseline with the battery terminal contacts or the earth straps?
Cheers Ad
Posted 03 October 2006 - 03:42 PM
Earths need to be clean and dry to work, smearing grease over them will not do you any favours.
Rub them with some wet and dry to freshen the surfaces, degrease with some white spirit and then do them up. make sure they're tight and dry.
P.S.> Fuel has a shelf life of about 6weeks nowadays before it begins to go stale, Get some Shell Optimax (now branded as Shell 'Vpower') and chuck that through it,. cleans your system and shuold iron out some erratic running enough for you to get the mixture and timing set well enough to get it back down the rolling road!
Edited by Retro_10s, 03 October 2006 - 03:46 PM.
Posted 03 October 2006 - 05:59 PM
i was told many a year ago about the vaseline thingy being the only grease/lubricant you could use with electrical terminals because it doesnt interfere with the current!!!!
i used to be a bus mechanic and we all always swore by it and got no problems!! i could so easily be wrong so many little old school things out there and some could be utter rubbish!!
Posted 03 October 2006 - 06:12 PM
Posted 03 October 2006 - 06:15 PM
Posted 03 October 2006 - 06:25 PM
Posted 15 October 2006 - 08:43 AM
jerry
Posted 15 October 2006 - 09:03 AM
