car not firing
29 replies to this topic
#1 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 10:43 AM
Hello all
Sorry to bother you again, guessworks supplied me with a new starter motor which I fitted, then fired the baby up and she sterted first time, not running right tho but it was a start, I turned ignition off to move car outside as i was getting choked in the garage, turned the key and it started first time, running really rough at this point tho only firing on 1 cylinder! I decided to start all over again with the timing to see if I can get it right. Found TDC, put dizzy drive shaft in correctly. Set dizzy static timing, everything was looking good until I turned the key and it doesnt even atempt to fire now, it turns over no probs. There is a decent spark at the plugs.
Any ideas of anything else it could be?
Gaz
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 October 2006 - 11:46 AM
is the dizy cap 180 degrees out ? :gimme:
#3 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 11:49 AM
dont think so, I have tried it in every single position I can think of!
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 October 2006 - 11:54 AM
leads in the right order 1342 i think
#5 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 11:55 AM
yep 1342 anti clockwise with 1 faceing towards number 1 cylinder
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 October 2006 - 11:56 AM
fuel and new fuel :gimme:
#7 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 12:01 PM
plenty of fuel in there i think good point.
#8 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 12:14 PM
Just checked and there is plenty of fuel. I am completely puzzled
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 October 2006 - 12:16 PM
thats 2 of us now :gimme: :gimme:
Edited by bungle, 02 October 2006 - 12:16 PM.
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 02 October 2006 - 01:00 PM
voodoo curse?
edit
contact breakers perhaps (reading haynes here so it probly wrong) :gimme:
oh wait. Pleant of Fuel WERE? might be somthing blocking a pipe so top the float up yourself or at lest see if theres any petrol in the float.
just an idea tho.
Edited by Big_Adam, 02 October 2006 - 01:02 PM.
#11 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 03:20 PM
contact breakers are brand new, correct distance apart etc etc.
Plenty of fuel going through into the carb then fuel covering the plugs.
#12 Big_Adam
Big_Adam
  • 7,435 posts
Posted 02 October 2006 - 03:41 PM
ah....errm....rolloxs.
i'll go back to my voodoo curse idea then,
#13 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 02 October 2006 - 03:47 PM
silly question but are you using the choke?
#14 miniman207
miniman207
  • 165 posts
Posted 02 October 2006 - 03:50 PM
yep tried it with the choke, without the choke!!!!
The only thing I can think of is like adam said a voodoo curse!!
#15 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 02 October 2006 - 03:53 PM
when you changed the points did you also change the condensor?
how's your coil... though I guess it's fine if there's definatly good spark.
I can only see it being timing related, if you've got spark, and fuel.. then surely the only thing stopping it firing is timing out.
have you checked the head over? are you flooding the engine?
