Everytime it rains or is damp. my starter motor wont turn, have to give it a tap with a wheel brace or summit simular.
any ideas?
Starter Motor
JoeBodge
, Oct 02 2006 12:27 PM
6 replies to this topic
Posted 02 October 2006 - 12:27 PM
Posted 02 October 2006 - 12:40 PM
sounds like a new one dude!
Posted 02 October 2006 - 12:59 PM
well could pop it open a give it some lube with disel i think.
i used wd40 which i found to be bad. then i just got a new one for £30 from motor factors.
Posted 02 October 2006 - 01:21 PM
when I bought my first mini for my ex, the starter was a sticky bugger, so I Dipped the whole lot in a vat of Electrical Switch cleaner fluid (I build guitars so had lots around... works wonders!) and then I let it dry, re attatched it, Bingo, never caused problems... proably should've lubed it up too though lol.
Just get a new one.
Just get a new one.
Posted 02 October 2006 - 07:14 PM
I'd guess at water in the connectors, but pop it off, make sure it's all clean and not corroded, give the connectors a proper clean inside and out, spray some WD40 about a bit and pop it back on. Also wouldn't hurt to check the connections on the starter solenoid as on some minis this is below the windscreen washer tank, so in cold water forms condensation, this drips onto solenoid, gets into electrics and stops it working so well, the wonders of mini design!
Good luck,
Dave
Good luck,
Dave
Posted 02 October 2006 - 08:58 PM
thanks for your help - will give it a go tomorow. anythings better than wacking it with a wheel brace in pouring rain. lol
Posted 02 October 2006 - 09:23 PM
man you don't know hard fixing untill you've changed a petrol pump in the snow.
that was a fun day. espicaly when i could feel my hands again.
