electrics again
Posted 02 October 2006 - 10:15 PM
anywho. falsher units have been replaced, hazard switch, earths checked.
the problem is intermittent, sometimes they both work sometimes only the left one works. the hazards work but flash randomly now, quite fast.
now, if it was a crappy earth on one light, surely the hazards would not work all the time?
as far as i can tell from the wiring diagram in haynes, the hazard switch is linked in to where the switch for the indicators is. jumping the connections on the back of the hazard switch proves no change.
i struggle to see how it could be wiring when it was all fine and dandy before, then suddenly went wrong. and how it sometimes works absolutely fine.
if the hazard switch is linked in past the indicator switch, and all the lights work when the hazards are on, this must mean that all the wiring past the hazard switch is fine?
and the only thing before that in the circuit is the actual stalk itself on the column, and the wiring leading off that.
should i reaplce my controls on the steering column and see if that fixes it? or if anyone has any other ideas?
sorry for the confusing post.
Posted 02 October 2006 - 10:18 PM
If it has inline fuses check them as the plastic housings can seperate or just a dodgy connection between the fuse and connectors.
Posted 02 October 2006 - 11:32 PM
Posted 02 October 2006 - 11:34 PM
its an 89. has inline fuses. checked em and seem ok, but surely the indicators arent run off this anyway, plus if it was the fuse the both sides wouldnt work?
Not 100% bout this but some have inline connections for each side. maybe
Posted 02 October 2006 - 11:36 PM
well ive got the four fuse box which does indicators on the first fuse, and an inline behing the airbox which does the hazards?
Posted 02 October 2006 - 11:44 PM
Edited by ginger_monkey, 02 October 2006 - 11:45 PM.
Posted 03 October 2006 - 09:13 AM
If the only thing that is still in the loop now is the stalk, then this could be your problem. My main beam and down wipe doesn't work on mine but after taking it out and having a play I found that the metal connections needed a bit of a tweak to give them a bit more spring. The stalks work by forcing a thin metal strip with a blob of carbon on the end on to another thin peice of metal with a blob of carbon on the end (hope this makes some sort of sense). When i took mine off to have a look I found loads of fluff and C**p coated the connections. A quick wipe with a bit of emery cloth on the blobs to give a clean connection and a bit of a bend with some long nose pliers sorted mine out.
Have a go
You never know!?
Hope this helps.
Posted 03 October 2006 - 09:30 AM
Posted 03 October 2006 - 11:16 PM
can anyone verify that if all hazards work it cant be any connections after where the hazards join in? makes sense to me...
did electronics at school but building something that automatically grows a plant with auto lighting, water, temp, humidity etc was a lot easier than a bloody mini.
thanks a lot for the advice of cleaning the switch, it could just be that. i take the whole lot off yes? and undo the connector at the bottom of the steering cloumn? looks a bit hard to get to from undrneath.
stef
Posted 04 October 2006 - 10:38 AM
And it's available new from here:-
Mini Sport Flasher Unit - Lucas
I'm told there is also a simple test you can do with the hazard flasher. Take the flasher out, and link the 2 connections it plugs in to with a piece of wire. Then turn the hazard switch on. If the hazards light up then the flasher is faulty, if not then the problem is probably elsewhere?
Oh and check the Hazard Warning Light Flasher Unit holder, because the wires behind it can get corroded and cause havoc too.
Here's a list of all the fuses and in-line fuses which may help:-
1: 1-2 35amp Brake Lights, Reverse Lights, Direction Indicators & Rear Screen Demister.
2: 3-4 25amp Horn, Headlamp Flasher, Brake Failure Circuit & Radio Memory.
3: 5-6 25amp Heated Blower Motor, Windscreen Wipers, Washer Motor & Instruments.
4: 7-8 15amp Side & Tail Lights, Panel Lights & Instruments.
The circuits covered by fuse 1 only operate with the ignition switch at position “II”.
The circuits covered by fuse 3 only operate with the ignition switch at position “I” or “II”.
The following fuses are in-line Fuses situated behind the air-filter on the bulkhead:-
15amp - Purple/Orange Wire Hazard Warning & Interior Lamps
15amp - Brown/Orange Wire Dim-Dip Lighting
10amp - Blue/Orange Wire Rear Fog Guard Lamps
15amp - Blue/Red Wire Auxiliary Cooling Fan (where fitted)
Posted 04 October 2006 - 11:14 AM
I work on Harrier GR7/9 electrics, give me a weapons/autopilot/undercarriage system and ill have it fixed in a couple of hours.
But minis! they are so tempermental!
Edited by Bounce, 04 October 2006 - 11:17 AM.
Posted 04 October 2006 - 11:24 PM
i noticed that one connection (to indicate right) was able to be pushed in and out of its housing, therefore i thought this was the problem because it wasnt connecting properly.
so after putting it back together, with the bits in the wrong place, i took it all apart again and finally fixed it all.
and it worked!
of course 5 seconds later it stopped working again.
so im now guessing its not the stalk either. so i dont have a clue what to do next. sometimes it works sometimes it doesnt. i looked at the connection block at the bottom of the steering column, and that seemd ok. its strange how some connections on the block are silver and some gold?
at least i need to buy a genuine flasher unit, mine flashes really fast and then slow lol. so my hazards will be fine, just the indicators to sort.
as a side note, i tried taking out the indicator flasher, and jumping the connections. indicate left and the left ones all came on (no flashing of course), indicate right and they all came on, but then blew the fuse in the fuse block, only had one spare so havent tried it again lol. if that helps...
stef
Edited by stef, 04 October 2006 - 11:24 PM.
Posted 05 October 2006 - 05:52 PM
Or you could try Moss:-
Moss Europe Link
Edited by taffy1967, 05 October 2006 - 07:03 PM.
Posted 05 October 2006 - 09:12 PM
