Bleeding New Brakes - Pistons Retract When Pedal Is Released
brakes
Best Answer Spider , 01 February 2018 - 05:55 PM
I think you'll find the seals are dry. They will retract a little in normal use, but not to the extent you are seeing and this came up elsewhere recently.
The fix is easy.
One at a time, remove a pad, pump the piston out 4 - 5 mm and push it back, replace the pad. Repeat this with all Pistons.
This will lubricate the seals with Brake Fluid and allow them to settle where they need to.
Go to the full post
14 replies to this topic
#1 mattcave
mattcave
  • 93 posts
Posted 01 February 2018 - 04:19 PM
I've just replaced my 8.4" disks/calipers with a (brand new) 7.5" setup. I'm struggling to bleed them. The lines all seem OK, no leaks. There's no air in the rear lines, I'm confident of that. It's a 1993 SPi car with servo. Master cylinder was fine before the conversion.
When I open the bleed nipples I'm getting clear fluid through, no air bubbles. However, when my assistant depresses the brake pedal, I can see the pistons on the front callipers move inwards few millimetres, and when the pedal is released the pistons retract again - so I never get a solid pedal as the pistons/pads never make contact with the disk face. I can't remember coming across this problem before. What's going on here, and how do I fix it?
Thanks!
#2 mini13
mini13
  • 3,810 posts
Posted 01 February 2018 - 04:24 PM
try wedging the pedal hard down with a peice of wood under the steering wheel over night. it may be that the seals just need " helping"
#3 nicklouse
  • 18,601 posts
Posted 01 February 2018 - 04:32 PM
yes pistons do retract when the pressure is removed.
how do you mean
they have to when you press the pedal.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 01 February 2018 - 04:36 PM
Thanks!
So what happens when you pump the pedal, does it then go solid?
#5 mattcave
mattcave
  • 93 posts
Posted 01 February 2018 - 04:41 PM
Push pedal to the floor, calliper moves in, but not far enough for the pads to contact the disk.
Release pedal, calliper retracts, back to where it started.
Repeat 10 times, calliper still ends up where it started (ie almost fully retracted).
Make more sense now?
Edited by mattcave, 01 February 2018 - 04:46 PM.
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 01 February 2018 - 04:48 PM
No, what I meant was, if you pump it quickly, does the pedal then go solid?
#7 nicklouse
  • 18,601 posts
Posted 01 February 2018 - 04:50 PM
sounds like the valve is cutting in thinking you have a leak.
#8 mattcave
mattcave
  • 93 posts
Posted 01 February 2018 - 04:56 PM
Ah, gotcha. Just tried that...
Pump it 4 or 5 times, and the pedal does indeed go hard. So that's good! And if I hold the pedal down, it stays hard, doesn't slowly go down to the floor, so that confirms there are no leaks.
If I take my foot off the brake pedal for 5 seconds or so, the pedal then needs 3 or 4 pumps for it to go hard again. I guess because the pistons are slowly retracting again?
#9 mattcave
mattcave
  • 93 posts
Posted 01 February 2018 - 04:58 PM
Yeah, and I can see why it "looks" like a leak. There's resistance in the rear circuit, but not in the front circuit. Just not sure how I would go about resolving that.
#10 panky
panky
  • 1,791 posts
Posted 01 February 2018 - 05:15 PM
Just thought I'd suggest the obvious one - are the bleed nipples are at the top of the calipers?
#11 mattcave
mattcave
  • 93 posts
Posted 01 February 2018 - 05:45 PM
They are, yeah, thanks for checking though.
If there was still air in the system, the pistons wouldn't be moving.
#12 Spider
  • 14,895 posts
Posted 01 February 2018 - 05:55 PM   Best Answer
The fix is easy.
#13 mattcave
mattcave
  • 93 posts
Posted 01 February 2018 - 06:24 PM
The fix is easy.
Nice! It will have to wait for the weekend, but I'll give it a go and report back. Does sound plausible/sensible!
#14 nicklouse
  • 18,601 posts
Posted 01 February 2018 - 06:50 PM
gravity bleed or just press ridiculously gently and slowly.
#15 mattcave
mattcave
  • 93 posts
Posted 27 February 2018 - 04:53 PM
To close the loop on this one, the explanations / solutions proposed by Moke Spider and mini13 seemed to do the trick. Wedging the pedal down overnight improved things significantly (and proved what the cause was), and Moke Spider's solution nailed it properly.
Thanks both!
Also tagged with one or more of these keywords: brakes
