I've just replaced my 8.4" disks/calipers with a (brand new) 7.5" setup. I'm struggling to bleed them. The lines all seem OK, no leaks. There's no air in the rear lines, I'm confident of that. It's a 1993 SPi car with servo. Master cylinder was fine before the conversion.
When I open the bleed nipples I'm getting clear fluid through, no air bubbles. However, when my assistant depresses the brake pedal, I can see the pistons on the front callipers move inwards few millimetres, and when the pedal is released the pistons retract again - so I never get a solid pedal as the pistons/pads never make contact with the disk face. I can't remember coming across this problem before. What's going on here, and how do I fix it?
Thanks!
