Help! Water Running Straight Into Doors From Window
Posted 19 February 2018 - 08:18 PM
Just wondering if someone could help me. I have just bought a mini and it has had a significant water leak from the bottom of the two doors into the foot wells. I changed the door rubbers which made no difference. When I jet wash it water literally pours into the car from the bottom of the doors. I have today noticed that where the windows meet the door (the strip mainly) there is about a half a centimetre or more gap in the middle where water just runs straight down the window into the door itself. It looks like the doors are bowing out in the middle and I think all the water is coming in from there. It is definitely not water tight. The doors currently have no rust and Im really worried that the doors and footwells are going to rot if I dont fix it ASAP. Does anyone know why this might be and how to fix it?
Posted 19 February 2018 - 08:57 PM
Are the drain holes blocked in the bottom of the door, there should be three there.
Posted 19 February 2018 - 09:11 PM
Posted 19 February 2018 - 09:18 PM
Do you mean the doors weather strip has a bow in the middle MSSK2104 .
if so it is likely that replacement door skins have been fitted at some time possibly without the strengthening panel.
The water is most likely coming in through the badly sealed apertures behind the door trim. its just a case of popping the door trims off and correctly sealing the apertures.
I use foil tape personally but a quick search should give you a few ideas.
Posted 19 February 2018 - 09:24 PM
Posted 19 February 2018 - 09:49 PM
Have you cleaned the drain holes in the doors themselves? If your door cards are wet, that could be your problem. I had the same issue. I drilled out the hole to make it slightly bigger. Just make sure you rust proof afterwards. Hopefully that works?
Posted 19 February 2018 - 09:50 PM
If the skin is bowed out after a reskin then you have to remove the outer weather strip and gently push in the centre at the top of the skin. Now you may not get enough deflection here as the window even wound down will stop you pushing too far. This may be enough but be very careful because if you push too hard you can crease the door.
If you do not get enough deflection then it's window out time.
Posted 19 February 2018 - 10:42 PM
A photo would help....
Posted 19 February 2018 - 10:54 PM
Posted 20 February 2018 - 03:38 PM
Posted 20 February 2018 - 03:50 PM
Posted 20 February 2018 - 04:00 PM
Posted 20 February 2018 - 04:10 PM
As stated it can be sorted by gently bending the door skin back and refitting the weather strip
Is there a plastic weather shield behind the door card ? if not this will also let water into the car
some folk tape up the holes if one is not fitted
Posted 20 February 2018 - 04:16 PM
Posted 21 February 2018 - 03:43 PM
I'm not sure but I will take the doors apart at the weekend and find out. If one isn't there can I get them online easy enough do you know? Thanks for the advice
Here is the part number from Minispares
DL3030 About £10 don’t forget if you become a TMF+ member you get 7.5% off from Minispares
Good luck
Mark
