Posted 20 February 2018 - 08:05 AM
Posted 20 February 2018 - 08:11 AM
most likely to be vetro. but for 10 (or so bolts) why guess.
Posted 20 February 2018 - 09:10 AM
Its a blanked timing hole with thread plugs and the flywheel is a verto type
Posted 20 February 2018 - 09:49 PM
Looks like its a verto to me, but simple check, use a mirror and torch inside the starter motor aperture and look at the clutch type between the wok and flywheel.
Posted 21 February 2018 - 10:24 PM
Posted 21 February 2018 - 10:27 PM
Posted 22 February 2018 - 09:03 AM
take the lid off to check the clutch type but also to count teeth to find out which starter motor you need.
Posted 22 February 2018 - 11:20 AM
Posted 24 February 2018 - 10:06 PM
Posted 24 February 2018 - 10:08 PM
it is a verto clutch yes.
Posted 24 February 2018 - 10:11 PM
Yes, you can fit a lightened flywheel with verto - Minispares do one that I'm going to use in my 1275 build
Posted 25 February 2018 - 09:12 AM
Posted 26 February 2018 - 01:05 PM
I agree just take the wok off and look. It'll only take a few minutes.
Posted 26 February 2018 - 01:06 PM
I couldnt see much with the mirror so the bolts came out. I think this is a Verto clutch???
LOL Ops just saw this. Yup Verto.
Mini Technical Sections →
Problems, Questions and Technical →
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
