New Built 1283 Poor Running
18 replies to this topic
#16 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 February 2018 - 11:50 PM
I thought stale fuel too, or maybe the float needle is not quite doing its job.
If you take the dashpot off, the fuel could be right to the top of the main jet or even running out of it if you flick the starter on/off
#17 mikal
mikal
  • 240 posts
Posted 25 February 2018 - 02:58 AM
Take the air cleaner off and dribble a bit of fuel or spray some hydrocarbon product directly into the carb and see what happens. ( I started a car once with flyspray!, A mates car wouldn't start and I suspected the fuel pump was u/s. All we could find was fly spray. Hey presto! The engine burst into life and ran as long as I sprayed!)
A "mechanic" had told him the fuel pump was ok.... Replaced the pump and all was good...
#18 Shaggy33
Shaggy33
  • 311 posts
Posted 25 February 2018 - 09:16 PM
Sorry for the late reply. Turned out to be plugs! Old ones were very coked up which worry me if engine has been running too rich! Fitted me plugs and all was fine however I decided to change oil today and it had a distinct smell of fuel....pump seems ok and no leaks there so not sure what causing it. My main concern is that the oil has been made thinner by the fuel and not protected engine.
Done and oil and filter change today and will take for another tune in the next few days.
Cheers guys
#19 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 27 February 2018 - 01:10 PM
Cheers guys
If the oil smells of fuel the diaphragm is split on the pump. Replace the pump
