Specialist Components Mpi Injection Kit
engine
6 replies to this topic
#1 mpialan
mpialan
  • 117 posts
Posted 25 February 2018 - 04:59 PM
Does anyone with a Specialist Components MPI Injection Kit fitted have photograph of how they have connected the various Breather System Hoses. I am not 100% sure that the way I have connected the Hoses is correct. See photo below.
Thanks in advance
#2 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 25 February 2018 - 05:27 PM
Thanks in advance
You find it better if you use imgur.com for your image hosting.
#3 mpialan
mpialan
  • 117 posts
Posted 25 February 2018 - 05:44 PM
https://imgur.com/a/z8nxX
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 25 February 2018 - 06:16 PM
If you click on the image you want a list of options will appear on the right side of the screen, scroll down to the bottom of the list and click copy and then paste the link into your post and it will display the pictures as opposed to the link.
#5 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 26 February 2018 - 12:34 AM
That wont work unless you have a 1mm restrictor in the breather connection onto the manifold.
If you look on the original MPi manifold and throttle body where the breather pipes connect, you will see it has a restrictor
#6 Steve220
Steve220
  • 5,049 posts
  • Local Club: BMC
Posted 26 February 2018 - 10:48 AM
Or ditch the entire charcoal canister system?
#7 mpialan
mpialan
  • 117 posts
Posted 26 February 2018 - 07:02 PM
https://imgur.com/U5clkgx
