Yep I used Mini spares genuine ones as well. I’ll take it all apart and double check but I’m 95% sure they are spot on. It seems to be at the top of the windows that they pinch so you can move the window from the lowest point by grabbing hold of it through the regulator hole and lifting it. But when it gets to around 4 inches from the top it just seizes absolutely solid. Its just odd doesn’t make any sense. Maybe the window glass is warped or something?
Fitting Window Regulator! :@
smithy3793
, Feb 26 2018 03:14 PM
15 replies to this topic
