cheers chaps - my shifts are all to ******* this week but will get the car jacked up at the weekend
Shocks Uneven - Can They Be Adjusted?
Best Answer happydude2012 , 25 July 2018 - 07:36 AM
just to close this one out, i did adjust the nut on the rear shocks and it evened it out - was a 20mm difference
Go to the full post
#16
Posted 08 March 2018 - 03:08 PM
#17
Posted 25 July 2018 - 07:36 AM Best Answer
#18
Posted 25 July 2018 - 09:22 AM
The height is set by the rubber spring cone, the trumpet and the knuckle joint. These are fixed unless a Hi-Lo is fitted which gives ride height adjustment.
#19
Posted 25 July 2018 - 09:27 AM
#20
Posted 25 July 2018 - 10:20 AM
explain plea.
#21
Posted 25 July 2018 - 10:50 AM
Aside from what was adjusted how would it be possible for only one corner to be high or low?
Unless the wheels aren't all on the same plane. There can only be 2 wheels at most in line with the body roll axis, so the suspension clearance above at least one other wheel must change.
A damper must be damaged to permanently alter the ride height. At best you've freed it, but it very likely still is damaged,
#22
Posted 25 July 2018 - 10:53 AM
or it could have that much damping added that it has over come the spring effectively locking it out. but that could also point to uneven corner weights..
#23
Posted 25 July 2018 - 02:48 PM
I put a spanner on the adjustable HI/LO cone nut.......turned it.....and as if by magic, the ride height changed....i know, weird.
Edited by happydude2012, 25 July 2018 - 02:49 PM.
#24
Posted 26 July 2018 - 03:46 AM
#25
Posted 26 July 2018 - 04:59 AM
Oh that's easy.
The shell needs to be twisted or loads of the spot welds broken.
#26
Posted 26 July 2018 - 07:47 AM
so nothing to do with the Dampers/shocks then.
#27
Posted 27 July 2018 - 10:13 AM
yeah i didnt think they were hilos, turns out they were. yes i said shock, my bad.
