Mpi Mini Maniflow Manifold
27 replies to this topic
#16 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 09 March 2018 - 05:29 PM
Hi, sorry but not sure what you mean by that?
This is what they are referring to. The lambda sensor in the Y piece as opposed to the centre downpipe.
No CAT... Cheeky
Doesn't need one. Its an earlier car, the lambda is for the 7 port injection ECU and was my choice to fit it.
#17 jamesmpi
jamesmpi
  • 1,940 posts
Posted 09 March 2018 - 05:34 PM
No CAT... Cheeky
Fair play 🙂
#18 Jarvey
Jarvey
  • Validating
  • 36 posts
Posted 12 March 2018 - 10:38 AM
Also, Jarvey - what ECU are you getting? Ive thought about getting one but the prices are so high.
I have ordered the Specialist Components MPI ECU & 50mm Throttle Body Kit with their Super Sport Cylinder Head!
Yeah much pennies! But once you have a mapable ECU it opens up more tuning options for the engine, be it turbo or supercharged it will benefit from a decent ECU. Even a standard engine will run better ... apparently.
#19 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 12 March 2018 - 12:34 PM
I'm extremely surprised they advised you to have a 50mm throttle body!
#20 Jarvey
Jarvey
  • Validating
  • 36 posts
Posted 12 March 2018 - 01:02 PM
How come Steve? What's wrong with it?! Haha
#21 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 March 2018 - 01:25 PM
The 50mm throttle body is great if you're going to spend a lot of time at very high revs but if you're building a tractable road engine and want torque especially with an SW5 cam, you'll be far better off with the 45mm throttle body.
#22 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 12 March 2018 - 01:35 PM
NP has pretty much hit the nail on the head. SC said they only recommend the 50mm TB for applications over 100bhp, otherwise you'll lose torque.
#23 Jarvey
Jarvey
  • Validating
  • 36 posts
Posted 12 March 2018 - 01:45 PM
Interesting! I wasn't advised what would be best for a daily road going engine. Although I did say end goal is running their Rotrex charger kit and they use the 50mm body as standard in that kit so maybe that is why.
Does 5mm on the diameter really make that much difference then?!
I am not planning on running an SW5i I am thinking of using a CST RE13OT or an ACD RS with 1.4 rockers.
#24 Jarvey
Jarvey
  • Validating
  • 36 posts
Posted 12 March 2018 - 01:46 PM
Oh dear haha I didn't know this! Doh!
Might be making a little phone call now!
#25 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 March 2018 - 01:48 PM
Its not the cam, its how hard and how long you're going to rev it over 7,500 revs. If you're going to force a lot of fuel in because it's turbo or supercharger then use the 50, otherwise stay away from it.
#26 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 12 March 2018 - 02:07 PM
I run a 50mm, SW5, 93lbft of torque from 2k to 7k.
#27 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 March 2018 - 02:13 PM
Have you tried it with a 45? I was down at AP Tuning in Norwich when they did the back to back tests using the SW5 with the 45 and the 50 and while the 50 was drivable, the 45 gave far greater torque.
#28 brivinci
brivinci
  • 1,210 posts
Posted 12 March 2018 - 04:04 PM
I'd love to see the curves from that testing Mr. 7-port. Hell, I'd love to see any dyne runs with the SC kits. Especially one with a before and after the install.
Now, back on topic a bit: I wrote Maniflow about having a Lambda ported added to the Y-pipe and they said it would be no problem BUT said that, in their experience, the sensor doesn't work well there. Said the exhaust is too cool at that point. They said they would add a port there and supply a plug for it so I could swap from upper to lower locations and see what works.
