Steering Wheel Vibration
3 replies to this topic
#1 idaz
idaz
  • 22 posts
Posted 14 March 2018 - 07:37 AM
1990 Mini
Stock condition
998cc
The steering wheel in my mini has been having a shaking fit. The worse of the shaking happens while in third and fourth gear. It does calm down though as I gain speed, roughly it will be very bad at 25 rpm and once I hit 30 rpm it only shaking a little bit.
I am thinking it may be a fuel issue, as the mini does feel as though it lacks power once I third gear.
#2 andyapanel
andyapanel
  • 642 posts
Posted 14 March 2018 - 08:22 AM
I would look to the wheels first; have you lost a balance weight?
Good luck
#3 JPN173
JPN173
  • 21 posts
Posted 14 March 2018 - 11:23 AM
i would also suggest looking at the front wheels first before anything else, sounds like they are unbalanced.
Hope this helps
#4 RooBoonix
RooBoonix
  • 1,225 posts
Posted 14 March 2018 - 11:53 AM
Have you got a steering drop bracket fitted?
If so, it'll probably be one of, or a combination of unbalanced wheels, excessive wheel/tyre run out and the drop bracket. I've just tackled this problem myself and removing the drop bracket help alot. I'm interested to try the DSN bracket to see if that is any more solid.
